The context:
Access to the console is via an LDAP admin group, so each admin has an account like admin_admin1.
I've noticed that on client PCs, I find these users in c:\users\admin_admin1.
Is this normal WAPT behavior, or should we use a generic account to avoid cluttering the PCs?
WAPT 2.5.5.15640 Enterprise
[RESOLVED] Admin account created on hosts
- WAPT Expert
- WAPT Expert
Hi Benoit,
if you're escalating privileges to launch the console with an admin account to enable Kerberos authentication, it's normal for there to be a local directory for that account on the admin's machine. Windows treats privilege escalation as a login (with the user directory and all that).
However, this shouldn't create accounts on every machine in the network.
Regards,
Regards,
Ultimately, WAPT wasn't the problem (another deployment in the same week --')
Otherwise, I have a real question,
My users have reported that PC shutdown has been slow since the installation of the Wapt agent
I have logs
I have logs
- 2024-07-11 20:42:37,082 [wapttasks SocketIOClient 12276] INFO Connecting Socketio to https://superserver.cab.local:443
2024-07-11 20:42:37,184 [waptws SocketIOClient 12276] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2024-07-11 20:43:37,194 [wapttasks SocketIOClient 12276] INFO Socketio connection params have changed. Socketio needs reconnect
2024-07-11 20:43:37,194 [wapttasks SocketIOClient 12276] INFO Creating socketio client: https://superserver.cab.local:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\superserver.cab.local.crt
2024-07-11 20:43:37,194 [wapttasks SocketIOClient 12276] INFO Connecting Socketio to https://superserver.cab.local:443
2024-07-11 20:43:37,278 [waptws SocketIOClient 12276] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2024-07-11 20:44:37,291 [wapttasks SocketIOClient 12276] INFO Socketio connection params have changed. Socketio needs reconnect
2024-07-11 20:44:37,291 [wapttasks SocketIOClient 12276] INFO Creating socketio client: https://superserver.cab.local:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\superserver.cab.local.crt
2024-07-11 20:44:37,291 [wapttasks SocketIOClient 12276] INFO Connecting Socketio to https://superserver.cab.local:443
2024-07-11 20:44:37,401 [waptws SocketIOClient 12276] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2024-07-11 20:45:37,418 [wapttasks SocketIOClient 12276] INFO Socketio connection params have changed. Socketio needs reconnect
2024-07-11 20:45:37,418 [wapttasks SocketIOClient 12276] INFO Creating socketio client: https://superserver.cab.local:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\superserver.cab.local.crt
2024-07-11 20:45:37,418 [wapttasks SocketIOClient 12276] INFO Connecting Socketio to https://superserver.cab.local:443
2024-07-11 20:45:37,450 [waptws SocketIOClient 12276] WARNING Exception ConnectionError('Connection error'), waiting 60s before retrying
2024-07-11 20:46:37,468 [wapttasks SocketIOClient 12276] INFO Socketio connection params have changed. Socketio needs reconnect
2024-07-11 20:46:37,468 [wapttasks SocketIOClient 12276] INFO Creating socketio client: https://superserver.cab.local:443 client auth cert: ('C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.crt', 'C:\\Program Files (x86)\\wapt\\private\\ordi1.cab.local.pem') proxies: None verify_cert: C:\Program Files (x86)\wapt\ssl\server\superserver.cab.local.crt
- WAPT Expert
- WAPT Expert
Hello Benoit,
thank you for keeping each forum topic separate. I'm closing this one; please open a new one for this second topic.
Regards,
Regards,
