tis-java8 / ERROR status
Answer
Aramis
Registration: July 16, 2024 - 11:48
August 1, 2024 - 2:24 PM
I am using WAPT Enterprise version 2.5.5.15691 on a Debian 12.6 server (6.1.94-1 (2024-06-21)).
I attempted to deploy the tis-java8 package to workstations through an AD organizational unit.
I get the following error:
Installing: drsilil-java8
WARNING: A Java Runtime Environment 8 (JRE) will be installed with WAPT since this package allow arbitrary install based on available package in a specific order
Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
  File "<string>", line 1939, in run
    self._run()
Exception: Erreur lors de l'installation de ['drsilil-java8(=10.0-2)']: erreurs dans les paquets [[PackageRequest(package='drsilil-java8',version=(Version('10.0.0.0'), 2),architectures=['x64'],locales=['fr'],maturities=['PROD'],tags=['windows-10', 'win-10', 'w-10', 'windows10', 'win10', 'w10', 'windows', 'win', 'w'],min_os_version=Version('10.0.19045'),max_os_version=Version('10.0.19045')), PackageEntry('drsilil-java8','10.0-2' maturity='PROD',target_os='windows'), 'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 5348, in install\n    result = self.install_wapt(p.localpath,\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4328, in install_wapt\n    raise e\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4235, in install_wapt\n    exitstatus = setup.install()\n  File "C:\\WINDOWS\\TEMP\\waptj_8j0rpe\\setup.py", line 35, in install\n  File "C:\\Program Files (x86)\\wapt\\waptutils.py", line 1957, in error\n    raise EWaptSetupException(\'Fatal error : %s\' % reason)\nwaptutils.EWaptSetupException: Fatal error : ERROR: No Java Runtime Environment 8 (JRE) have been deployed on this system, please import and deploy the package adapted to your organization\n']]
    self._run()
So, I'm thinking that this isn't the right adapted version.
I remove the package from the list of packages to be installed in this OU.
I have consistently had an error in the status of each machine.
So I tried the wapt-forget-packages package by correctly specifying the tis-java8 package, but without success since this package is ultimately not installed on the machines.
The error persists in the console with an error status for each machine.
Consulting the forum, the advice given is to use the "forget the package" command.
But this command is not available when I select a machine.
How can I restore the status of each machine and permanently remove the installation of this package?
Thank you for any advice you can give me.
August 14, 2024 - 1:25 PM
The tis-java8 package is quite specific.
It attempts to install one of the following packages:
tis-adoptium-openjdk8-jre,
tis-oracle-java8-jre-free,
or tis-oracle-java8-jre-nonfree.
Therefore, your repository must contain at least one of these three packages.
Depending on your Java usage requirements, it's up to you to decide what you want.
Answer
