[SOLVED] Endless WUA Scan
erems
Registration: Apr 25, 2023 - 3:52 p.m.
November 13, 2024 - 10:08 AM
We are experiencing a problem with Windows updates on some WAPT agents.
WAPT is version 2.5.5.15697. The agent configuration is as follows:
During a scan for Windows updates on the agent, the WAPT Exit never completes:
(He was found in the same condition the next day.)
The console displays the same thing:
erems
November 13, 2024 - 10:09
(Continuation of the previous message)
And if we run "wapt-get waptwua-scan", it doesn't return control either:
Finally, if I go to the Windows Update panel in Windows, it does see updates to be installed and installs them:
It doesn't seem normal to see the updates in this location when WUA is supposed to be enabled.
I don't see what's wrong with our setup. Can you help us, please?
THANKS.
Best regards.
November 13, 2024 - 4:00 PM
Hello
, could you try removing `include_potentially_supersed_update` and setting `
include_potentially_supersed_update=False`?
erems
November 15, 2024 - 3:17 PM
thank you, we'll try that and I'll keep you posted.
Best regards.
erems
November 25, 2024 - 11:26
since the setting was deployed, the situation seems to have returned to normal. I haven't noticed any other issues, and on the console side, WUA is back to green everywhere.
Thank you for your help.
Best regards.
November 25, 2024 - 11:30
Hello Erems,
thank you for the feedback :-)
. Best regards,
