[RESOLVED] Self-Service Malfunction
TomTom
Registration: May 25, 2018 - 3:43 p.m.
December 13, 2024 - 2:34 PM
Hello everyone,
Since update 2.6 (it's certainly getting a lot of flak!), it's no longer possible to display packages in the self-service portal. When we launch it, it displays the message "No results found."
No packages appear, and no categories are visible. There have been no changes to our permissions.
Thank you.
Thomas
WAPT version: 2.6.0.17392 (Enterprise Edition)
Server OS: Debian 12 "Bookworm"
Administration/package creation machine OS: Windows 11 24h2
blemoigne
Registration: July 17, 2020 - 11:29
December 16, 2024 - 10:17
I believe this bug is fixed in the latest version: 2.6.0.16613.
Have a good day,
Bertrand
TomTom
December 17, 2024 - 1:58 PM
Hello Bertrand,
No, I have the latest version installed and the Self still doesn't display anything.
December 17, 2024 - 2:02 PM
could you provide more information about the authentication type of the self-service? (waptserver-ldap, system, kerberos)
TomTom
December 17, 2024 - 2:07 PM
Hi Simon,
Yes, of course. We're using LDAP authentication (service_auth_type=waptserver-ldap).
December 17, 2024 - 2:34 PM
You would need to run this script on the server to see what it says:
/opt/wapt/waptserver/scripts/testing-ldap-connectivity.sh
TomTom
December 17, 2024 - 3:33 PM
WARNING: No ldap_account_service_login not found in /opt/wapt/conf/waptserver.ini
SSO self service authentication will not work
Test ldap with direct Login
Username ldap: user
Password ldap:
  File "<string>", line 114, in <module>
  File "<string>", line 111, in main
  File "<string>", line 77, in test_ldap
  File "/opt/wapt/auth_module_ad.py", line 33, in check_credentials_ad
    domain_name = dc_base_dn.lower().split('dc=', 1)[-1].replace('dc=', '.').replace(',', '')
AttributeError: 'NoneType' object has no attribute 'lower'
December 17, 2024 - 5:12 PM
In waptserver.ini you should put:
ad_domain_name = mydomain.lan
That should be better.
Don't you have Kerberos? (I see you don't have ldap_account_service_login)
TomTom
December 17, 2024 - 5:28 PM
Yes, we have Kerberos authentication and the ldap_account_service_login is correctly configured.
December 17, 2024 - 5:34 PM
Is the script being run as root?
