[SOLVED] MAC: Rustdesk
clafon
Registration: Nov 06, 2024 - 10:56
January 31, 2025 - 10:29
Wapt version: 2.6.0.16795 - Enterprise Edition
Server OS: Debian 12
Target machines: macOS 13.6.3 & 14.5
Administration machine: Windows Server 2022
we have installed and configured RustDesk on our Macs.
We can access them directly through RustDesk.
However, this doesn't work when we try to access them through the administration console. We right-click on the Mac and then select "Connect with RustDesk," but nothing happens.
Do you have any suggestions?
Thank you
January 31, 2025 - 1:36 PM
In the audit data, is the Rustdesk ID the same as the one you use manually?
clafon
February 4, 2025 - 9:38 AM
The rustdesk mac package is installed correctly on the Mac but I have nothing in audit data (no line with Rustdesk).
We retrieved the 1.3.7-aarch64 installation file; the setup.py is relatively simple:
r"""
    install_dmg('rustdesk-1.3.7-aarch64.dmg')
The Mac was configured manually.
Audit data from a PC where Rustdesk/Wapt is working correctly:
Audit data on a Mac where Rustdesk/Wapt is not working:
February 4, 2025 - 1:37 PM
Is rustdesk config installed?
clafon
February 5, 2025 - 11:20
Problem solved with update 2.6.0.16881
February 5, 2025 - 12:21
Hello Cédric,
thank you for the feedback :-)
