Wapt version: 2.6.0.16795 - Enterprise Edition
Server OS: Debian 12
Target machines: Windows 10 and 11
Administration machine: Windows Server 2022
we are experiencing a problem uninstalling the Chrome package from the self-service interface. Even when we click "uninstall," nothing happens and no error message appears in the administration console.
[SOLVED] Self-service: Chrome uninstallation
- WAPT Expert
Hello again,
and to add to Jordan's answer, it's true that the behavior isn't very intuitive... We'll try adding a popup to explain the reason for the installation refusal: either a direct dependency on the machine package, an OU package, a profile package, a group package, or a dependency on another software package.
Regards,
Regards,
- WAPT Expert
Hello Cédric,
Therefore, you cannot uninstall software that is assigned to a machine, only software that has been added in addition to the target configuration.
However, it's true that we could add an explanatory message. We're completely redesigning the self-service interface, so we'll see about adding a message at the same time.
Indeed, that was the behavior in older versions of Wapt. But it can cause problems in certain cases (for example, with antivirus software...).
