WAPTWUA version 2.6.0.17177
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
April 10, 2025 - 08:39
Good morning !
I installed the new version 2.6.0.17177.
Since this morning, the Windows 11 update 2025-04 has been released and I'm trying to install it, but I'm getting the following error:
Done searching
Updates scan done.
Merging installation history into scan results.
Writing status in local wapt DB
Updating workstation status on remote wapt server
- Get downloads for update 1248d549-d317-493f-a1db-f79fc8c0db48_100
Download Update 1248d549-d317-493f-a1db-f79fc8c0db48_100
Downloading windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu
Downloading windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu
Run dism command: "C:\WINDOWS\system32\dism.exe" /Online /Quiet /NoRestart /Add-Package /PackagePath:"C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu"
MSU KbFile installed C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5043080-x64_953449672073f8fb99badb4cc6d5d7849b9c83e8.msu with code 3010
Count of Updates to Install: 0
Count of actually installed Updates : 1
ERROR install update: Invalid floating point operation
Status:            ERROR, 1 pending, 6 discarded
Installed updates: 3
Pending updates:   1
Discarded updates: 6
Reboot required:
Last install date:   4/10/2025 8:34:49
Last install result:
WSUSScan cab date:   4/10/2025 5:10:32
April 10, 2025 - 09:38
guigeek wrote: ↑Apr 10, 2025 - 08:39 Run dism command: "C:\WINDOWS\system32\dism.exe" /Online /Quiet /NoRestart /Add-Package /PackagePath:"C:\Program Files (x86)\wapt\private\cache\windows11.0-kb5055523-x64_b1df8c7b11308991a9c45ae3fba6caa0e2996157.msu"
From what I can see, the installation worked, but when requesting a rescan of WUA to check the update status, the engine returns "Invalid floating point operation"
The machine should be here in pending reboot... installations are in progress here, run another scan to see?
guigeek
April 10, 2025 - 09:47
Doing a rescan after a reboot works, but I've never had the PENDING_REBOOT status.
However, I had to run the installation twice because the first time I got the following error:
ERROR 1 Missing files for update 1248d549-d317-493f-a1db-f79fc8c0db48_100 : http://dl.delivery.mp.microsoft.com/fil ... 996157.msu
Count of actually installed Updates: 0
Status: ERROR, 1 pending, 2 discarded.
I don't know if this will help.
Thanks
guigeek
April 10, 2025 - 09:48
Same kind of error with Windows 10:
Done searching
Updates scan done.
status
on
remote wapt
server
Downloading windows10.0-kb5055518-x64_941409af9ab0c70606d3fd1e39e5be67ecae40d3.cab
ERROR 1 Missing files for update 4861ab0d-9efc-46df-98a2-4aa7cb703e34_200 : http://download.windowsupdate.com/d/msd ... ae40d3.cab
Status: ERROR, 1 pending, 1 discarded
Installed updates: 6
Pending updates: 1
Discarded updates: 1
Reboot required:
You have to restart a second time for it to seem to work
April 10, 2025 - 09:56
ERROR 1 Missing files for update is "normal."
Actually, during the scan, the KB goes into "pending" status. And every 30 minutes, the server downloads the missing CAB files.
But if the machine is the first to see this CAB file as "pending," then it won't be able to download the CAB file from the server because the server hasn't had time to download the KB file.
Previously, the machine would remain in "pending" status in this case; now we flag it as "error" because it's more logical.
guigeek
April 10, 2025 - 10:01
Ah, okay, I understand better now.
So, indeed, if I rescan right after installation, it goes into PENDING_REBOOT.
Anyway, the "SCANNING" status is great!
guigeek
April 10, 2025 - 10:22
sfonteneau wrote: ↑Apr 10, 2025 - 09:56 ERROR 1 Missing files for update is "normal"
. Actually, during the scan, the KB goes into "pending" status. And every 30 minutes, the server downloads the missing CABs.
But if the machine is the first to have this CAB in "pending" status, then it won't be able to download the CAB from the server because the server hasn't had time to download the KB.
Before, the machine would remain in "pending" status in this case; now we flag it as "error" because it's more logical.
It's strange because it keeps happening to me for all of them, even though the cab has already been downloaded on the first, already updated, machine
guigeek
April 10, 2025 - 10:27
guigeek wrote: ↑Apr 10, 2025 - 10:22
Oh no, sorry, the error was the invalid floating point again
guigeek
April 11, 2025 - 08:37
Hello again,
after trying everything, I'm still having the problem (only on Windows 11) where the KB update remains in "PENDING" even though it's properly installed.
And as with previous updates, it doesn't happen on all machines.
In my tests, it happens on 20 out of 89 machines.
This randomness is very strange.
Thanks for your feedback
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
April 11, 2025 - 8:50 AM
did you run another scan after restarting the machines?
Answer
