DNS resolution has failed error message
Answer
fdumondel
Registration: May 6, 2025 - 09:04
May 6, 2025 - 09:17
when attempting to deploy an ISO via WAPT, I get stuck and receive the message "DNS resolution has failed for: ...".
I'm using VMware to test the ISO deployment. I hope I'm using the correct drivers.
Regards
Screenshot 2025-05-06 091514.png (68.07 KB) Viewed 9073 times
May 6, 2025 - 10:10
Hi Franck,
DNS resolution isn't working. Are you on a NATed bridge with a different DNS suffix than your production network? Could you please use a fully qualified domain name (FQDN)?
Is the IP connection working (ping the server's IP address)?
Regards,
fdumondel
May 6, 2025 - 10:34
Hello Denis,
ping works with the FQDN address and IP address (see attached image).
Screenshot 2025-05-06 103148.png (115.43 KB) Viewed 9049 times
May 6, 2025 - 10:57
Hello Franck,
It seems the DNS suffix isn't being considered at that point in the server connection. Unless the resolution is using NetBIOS broadcast? Normally, a fallback to the system resolver is used if there's no direct response, so it should have worked. But anyway, using FQDNs is a best practice.
Could you please enter a FQDN? By default, the configuration is taken from the dynamic "default" configuration (Option menu/"edit agent dynamic configuration"), you need to enter an FQDN name there and regenerate WinPE.
Clipboard - May 6, 2025 10_54.png (8.49 KiB) Consulted 9038 times
Clipboard - May 6, 2025 10_53.png (8.36 KiB) Consulted 9038 times
May 13, 2025 - 3:53 PM
Hello Franck,
did this solve your problem?
Regards,
Answer
