[SOLVED] Disable TOTP - 2FA
dsi_oll
Registration: May 14, 2025 - 09:11
May 21, 2025 - 4:05 PM
I would like to disable 2FA but I can't find the option.
I'm using Discovery version 2.6.0.17226.
The documentation says I need to go to user management to remove it, but I don't have that menu in my version.
Fabien
May 21, 2025 - 5:50 PM
Hello Fabien,
On the server, you can run the following command.
sqlite3 /opt/wapt/conf/security.sqlite "update waptusers set  otp_key=NULL where otp_key is not null;"
In fact the menu should have been greyed out, the OTP function is not available in Discovery.
dsi_oll
May 23, 2025 - 08:37
thank you for your reply.
WAPT is hosted on Windows with a PostgreSQL server, I believe.
Can you tell me if it's the same command?
Thank you in advance.
blemoigne
Registration: July 17, 2020 - 11:29
May 23, 2025 - 12:38
This one would be best for a WAPT Windows server:
wapt-get run "import sqlite3; db = sqlite3.connect(r'c:\wapt\conf\security.sqlite'); cur = db.execute('select name,otp_key from waptusers where otp_key is not null'); print(cur.fetchall())"
Have a good weekend,
Bertrand
dsi_oll
May 23, 2025 - 1:47 PM
the print function correctly outputs the OTP value but doesn't change it to NULL.
Is there perhaps another way to replace the current value with NULL?
Thank you
blemoigne
May 23, 2025 - 2:11 PM
oops :
wapt-get run "import sqlite3; db = sqlite3.connect(r'c:\wapt\conf\security.sqlite'); cur = db.execute('update waptusers set  otp_key=NULL where otp_key is not null'); "
dsi_oll
May 23, 2025 - 2:45 PM
Sorry, but that doesn't work.
It doesn't modify the "admin" entry.
Screenshot 2025-05-23 144457.png (46.66 KB) Viewed 24456 times
May 26, 2025 - 10:09
add a db.commit();
after the SQL update query
wapt-get run "import sqlite3; db = sqlite3.connect(r'c:\wapt\conf\security.sqlite'); cur = db.execute('update waptusers set  otp_key=NULL where otp_key is not null'); db.commit();"
dsi_oll
May 26, 2025 - 10:37
Perfect,
thank you. Have
a good day.
