The tis-vlc package does not update older versions
Answer
markham
June 23, 2025 - 3:13 PM
Despite the presence of VLC version 3.0.21 in the repository, the initially deployed version 3.0.20 is not being updated.
All machines remain green, despite the presence of the older VLC version.
To clarify, the versions (the installed one and the new one) do not come from the same source. The installed version comes from an older version of WAPT, which has since migrated to the newer version. This older installation did not come from the store, but it has the same name
and the associated package was recognized (I see it in the console under "Installed Packages"). However, it is not updating. (Note: the certificates have changed.) The version on the website has the same name and follows the same numbering system
: the installed version is
iep-vlc 3.0.20-30,
while the version from the store is
iep-vlc 3.0.21-13.
How can I fix this problem?
Thank you.
blemoigne
Registration: July 17, 2020 - 11:29
June 23, 2025 - 5:49 PM
You need to pay attention to the target OS and the architecture (among other things) of the newly imported VLC package. Is it properly built for Windows x64?
Best regards,
Bertrand
markham
June 27, 2025 - 08:36
To clarify, the versions (the installed one and the new one) don't come from the same source. The installed one comes from an older version of Wapt, which has since been migrated to the new one. This older installation didn't come from the store, but it has the same name
The associated package was recognized (I can see it in the console under "Installed Packages"), however, it's not updating. (Note: the certificates have changed), with the website version having the same name and following the same numbering system
the one installed:
iep-vlc 3.0.20-30
that of the blind:
iep-vlc 3.0.21-13
blemoigne wrote: ↑June 23, 2025 - 5:49 PM Hello,
Best regards,
Bertrand
blemoigne
June 27, 2025 - 09:54
The certificate that signed the package must indeed be deployed on the WAPT agents in order for them to be able to install it.
Can you also verify that the Target OS, architecture, etc., correspond to the image below?
July 4, 2025 - 12:32
Hello Markham,
were you able to resolve your problem?
Regards,
Answer
