[SOLVED] Problem with the tis-remove-windows-appx-template package
Mikael S
Registration: January 20, 2025 - 3:54 PM
July 16, 2025 - 08:36
In the session setup, you call the 'appx_to_uninstall.json' file on line 55.
However, the cache has since been cleared, and the file along with it. It needs to be copied elsewhere for the session setup to work on all sessions.
Regards,
blemoigne
Registration: July 17, 2020 - 11:29
July 22, 2025 - 11:10
Hi Mikael,
Yes, there was a small typo, it's been corrected and the package will be available soon. Thanks for letting me know.
Have a good day,
Bertrand
blemoigne
July 22, 2025 - 11:21
In the meantime, it is available on the testing repository: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
July 22, 2025 - 5:02 PM
Hi Mikaël,
does the package update resolve the issue?
Regards,
Mikael S
July 23, 2025 - 2:23 PM
Yes, that's all good then.
Regards,
July 23, 2025 - 2:49 PM
Hello Mikaël,
thank you for reporting the bug and for the validation :-)
. Regards,
