In the session setup, you call the 'appx_to_uninstall.json' file on line 55.
However, the cache has since been cleared, and the file along with it. It needs to be copied elsewhere for the session setup to work on all sessions.
Regards,
[SOLVED] Problem with the tis-remove-windows-appx-template package
In the meantime, it is available on the testing repository: https://wapt.tranquil.it/wapt-testing/t ... EPROD.wapt
- WAPT Expert
Hi Mikaël,
does the package update resolve the issue?
Regards,
Regards,
- WAPT Expert
Hello Mikaël,
thank you for reporting the bug and for the validation
. Regards,
. Regards,
