Hello everyone,
Recently (probably following our latest WAPT update), clients can no longer install packages via the WAPT Self-Service portal. It displays "No results found."
LDAP authentication is enabled on the server. I've tried using `service_auth_type=waptserver-ldap` and `filetoken`, but nothing works.
Have I missed something?
Thanks in advance,
Thomas
[RESOLVED] Empty self-service
- WAPT Expert
is this due to a WAPT upgrade?
To revert to the previous version's mode, switch to:
service_auth_type=system
, but logically filetoken should work.
Hi Simon,
I'm not sure if this is due to the latest update. However, changing the parameter to "system" doesn't work either.
- Attachments
- 2025-09-30_14h16_45.png (45.79 KB) Viewed 19207 times
WAPT version: 2.6.0.17392 (Enterprise Edition)
Server OS: Debian 12 "Bookworm"
Administration/package creation machine OS: Windows 11 24h2
Problem solved. A colleague renamed a security group used for self-service.
You can close this.
Sorry for the time wasted helping me.
You can close this.
