[SOLVED] Problem with the virtualbox package
Mikael S
Registration: January 20, 2025 - 3:54 PM
September 30, 2025 - 3:12 PM
In the update package, you download the extensions in the format Oracle_VirtualBox_Extension_Pack-%s.vbox-extpac.
However, in the setup, you use a glob on Oracle_VM_VirtualBox_Extension_Pack-*.vbox-extpack.
As a result, the extensions are not installed.
Regards,
jlepiquet
Registration: Sep 3, 2024 - 4:09 p.m.
September 30, 2025 - 3:55 PM
Hi Mikael,
Oracle has changed the names of its files.
I'm modifying the package and running the build.
Thanks for your feedback.
Best regards,
October 6, 2025 - 1:21 PM
Hi Mikaël,
thanks for the update, the new package is now available in the store, I'm marking the topic as resolved.
Regards,
