In the update package, you download the extensions in the format Oracle_VirtualBox_Extension_Pack-%s.vbox-extpac.
However, in the setup, you use a glob on Oracle_VM_VirtualBox_Extension_Pack-*.vbox-extpack.
As a result, the extensions are not installed.
Regards,
[SOLVED] Problem with the virtualbox package
- WAPT Expert
Hi Mikaël,
thanks for the update, the new package is now available in the store, I'm marking the topic as resolved.
Regards,
Regards,
