Following the update of the Flash Player package from version 24 to 25, I'm getting this error on all machines:
"Installing flash for firefox
EWaptSetupException: Fatal error: msi file install_flash_player_24_plugin.msi not found in package."
Could you please suggest a solution?
Thank you in advance.
Flash update problem
- WAPT Expert
Oops, a small error crept in, I forgot a piece of the code.
The error has been corrected, you can use it again!
I've been trying to install Flash for a while now.
I keep getting this error message: `
CalledProcessErrorOutput: Command u'msiexec /norestart /q /i "install_flash_player_27_plugin.msi" ' returned non-zero exit status 1603.
Output:u''`
What do I need to do to make it work, please?
Rémi Larché
Output:u''`
Rémi Larché
