Flash update problem
ben543
Registration: March 14, 2017 - 2:15 PM
March 14, 2017 - 2:18 PM
Following the update of the Flash Player package from version 24 to 25, I'm getting this error on all machines:
"Installing flash for firefox
EWaptSetupException: Fatal error: msi file install_flash_player_24_plugin.msi not found in package."
Could you please suggest a solution?
Thank you in advance.
March 14, 2017 - 5:32 PM
Oops, a small error crept in, I forgot a piece of the code. :shock: :?
The error has been corrected, you can use it again!
ben543
March 15, 2017 - 10:23
Perfect, I just checked and it works, :D
thank you for the quick response :)
Larche
Registration: Oct 12, 2017 - 09:26
October 12, 2017 - 09:32
I've been trying to install Flash for a while now.
I keep getting this error message: `
CalledProcessErrorOutput: Command u'msiexec /norestart /q /i "install_flash_player_27_plugin.msi" ' returned non-zero exit status 1603.
Output:u''`
What do I need to do to make it work, please?
Rémi Larché
