Regarding the new proxycache feature,
how is the SSL part handled?
In my case, I had configured the repositories and Nginx with my root CA.
Is the WaptServer HTTP server using httpd?
Can the proxycache package already be installed on WaptServer version 2.6?
Thank you for your answers,
Joshua
[SOLVED] Request proxycache info wapt 2.7
- WAPT Expert
The package installation handles the migration of the previous HTTPS certificate (the one that was in the nginx or remote HTTP server repository)
So normally the migration should happen automatically if the files were correctly placed in the expected location
No, it's a Mormot2 HTTP server. So nothing like what you've seen elsewhere.
Yes, it already works with version 2.6 (the latest 2.6)
Here is the documentation: https://www.wapt.fr/fr/doc-2.7/wapt-proxycache.html
and a blog post: https://www.tranquil.it/proxycache-wapt/
Best regards,
Bertrand
Best regards,
Bertrand
