[SOLVED] Request proxycache info wapt 2.7
Joshua
Registration: May 27, 2026 - 09:26
September 24, 2026 - 11:33
Regarding the new proxycache feature,
how is the SSL part handled?
In my case, I had configured the repositories and Nginx with my root CA.
Is the WaptServer HTTP server using httpd?
Can the proxycache package already be installed on WaptServer version 2.6?
Thank you for your answers,
Joshua
September 25, 2026 - 09:20
Joshua wrote: ↑24 Sep 2026 - 11:33 How is the SSL part handled?
The package installation handles the migration of the previous HTTPS certificate (the one that was in the nginx or remote HTTP server repository)
Joshua wrote: ↑Sep 24, 2026 - 11:33 In my case, I had configured the repositories and Nginx with my rootCA
So normally the migration should happen automatically if the files were correctly placed in the expected location
Joshua wrote: ↑Sep 24, 2026 - 11:33 Is the http waptserver httpd?
No, it's a Mormot2 HTTP server. So nothing like what you've seen elsewhere.
Joshua wrote: ↑Sep 24, 2026 - 11:33 On a Wapt server version 2.6, can the proxycache package already be installed?
Yes, it already works with version 2.6 (the latest 2.6)
Joshua
September 28, 2026 - 08:58
Hi,
Great, thanks for the clarification.
I imagine I need to create a new dynamic agent?
Is there any documentation available on this?
Thanks,
have a good day,
Joshua
blemoigne
Registration: July 17, 2020 - 11:29
October 1, 2026 - 5:12 PM
Here is the documentation: https://www.wapt.fr/fr/doc-2.7/wapt-proxycache.html
and a blog post: https://www.tranquil.it/proxycache-wapt/
Best regards,
Bertrand
Joshua
October 2, 2026 - 11:01
Hello Bertrand,
Thank you for your feedback
. Best regards,
Joshua
