Session Setup Error
srazer
Registration: Sep 28, 2017 - 8:18 p.m.
October 6, 2017 - 1:51 PM
Greetings,
On Windows 10 I am getting an error when running "wapt-get session-setup ALL". I get a pop-up message that states "The requested operation requires elevation." I do not get this with Windows 7.
Thank you,
Chris
October 6, 2017 - 8:13 PM
Hi Chris,
we have thousands of win10 running session-setup without any issue, so yes the behavior you get is unexpected. A few questions:
* what version of win10? is it the fall creator update?
* what packages have session-setup scripts that are run? Is it custom inhouse session update scripts, or it comes from TIS public repos?
* if you have setup session-setup at session startup (default behavior), do you also get a privilege elevation popup? Or is it only when you try to run it by hand?
* is the user local admin or non-privileged user?
* how is UAC configured on your win7 and win10. Is it default config in both cases?
Cheers,
srazer
October 6, 2017 - 9:08 PM
Hi Dennis,
Apparently something was corrupted in the workstation. I reloaded the computer and everything is working as it should. Thank you for the reply.
Thanks,
Chris
