is it possible to configure two different servers on the client: one for the /wapt-host and /wapt-group directories
, and one for the /wapt directory?
Basically, have the configurations on one side and the packages/installers on the other?
Thank you.
client with files on 2 different servers
- WAPT Expert
Yes, it's possible; it can even have its own settings. You need to modify the wapt-get.ini file on the clients:
[wapt-host]
repo_url=https://wapthost.mydomain.lan/wapt-host
verify_cert=1
http_proxy=http://srvproxy:3128
