Windows wapt-scanpackages.py
tienou
Registration: February 11, 2016 - 4:11 PM
February 12, 2018 - 1:46 PM
I'd like to set up repository replication.
I've looked at the documentation on this, but it's for Linux, while my servers are Windows.
Like any adventurous IT professional, I thought I'd give it a try.
I created a replication of the directory "drive:\wapt\waptserver\repository\wapt" between the servers, and that's OK.
However, the console isn't seeing the packages. It seems I need to run the wapt-scanpackages.py script.
The problem is, the script isn't present in "drive:\wapt\".
Help! :D
Thanks in advance.
agauvrit
Registration: Nov 17, 2016 - 10:25
February 12, 2018 - 2:43 PM
Scanning packages isn't mandatory since you'll be reading the Packages index, which is also present in your repository's directory structure.
Have you installed a web server to allow access to the repository via HTTP?
From our perspective, the most sensible option is to use WAPT Linux Server. ;)
Call us if you need assistance; our sales team will be happy to help.
Alexandre
tienou
February 12, 2018 - 5:32 PM
agauvrit wrote: ↑Feb 12, 2018 - 2:43 PM Hello,
Scanning packages is not mandatory since you will be reading the Packages index, which is also present in your repository's directory structure.
But of course.
pfff, that was a blunder on my part with the Package file.
Everything seems to be working now.
For your information, I'm doing a synchronization via DFS.
agauvrit wrote: ↑Feb 12, 2018 - 2:43 PM The most reasonable solution from our point of view is to switch to WAPT Linux server ;)
I agree, but I have some reasons.
agauvrit wrote: ↑Feb 12, 2018 - 2:43 PM Call us if you need help, our sales representatives will be able to assist you
Our salespeople? With a quote? That's not what I'm looking for.
Thank you Alexandre
