[SOLVED] Creating packages with iLok
Imp83
Registration: February 19, 2018 - 12:07
February 19, 2018 - 12:10
I'm working on a package for Pro Tools 12. The software installation goes smoothly, but
the iLok driver asks for developer authorization, and that's where I run into trouble. Without certificates, it's impossible to install.
Is there a way to retrieve the certificate once it's installed?
Thanks in advance!
admin-style
Registration: January 26, 2018 - 10:57
February 19, 2018 - 3:50 PM
You can retrieve the certificates by:
- ​​manually installing your driver on a computer
- then on that same computer running the command certmgr.msc (Certificate Store)
- You will then be able to retrieve the certificate
Imp83
February 19, 2018 - 5:05 PM
Ah yes, thank you!!!
