I'm working on a package for Pro Tools 12. The software installation goes smoothly, but
the iLok driver asks for developer authorization, and that's where I run into trouble. Without certificates, it's impossible to install.
Is there a way to retrieve the certificate once it's installed?
Thanks in advance!
[SOLVED] Creating packages with iLok
admin-style
- Registration: January 26, 2018 - 10:57
You can retrieve the certificates by:
- manually installing your driver on a computer
- then on that same computer running the command certmgr.msc (Certificate Store)
- You will then be able to retrieve the certificate
- Attachments
- export_CERTIF.jpg (28.14 KB) Viewed 3674 times
- mag_CERTIF.jpg (65.73 KB) Viewed 3674 times
