Waptconsole error message 1.5.1.16 community
ryoken95
February 28, 2018 - 8:31 AM
Good morning
I get the following message when I try to change my computer's settings:
Unable to edit the host profile
If package is signed with a foreign key, you may want to delete host package first to workaround the issue
Can you help me please?
Good day.
Regards
February 28, 2018 - 09:34
this message means that the signature of the current machine configuration (it's a WAPT package like any other) cannot be recognized with the certificates currently in the directory
Perhaps it was created with a different key?
The "simple" solution is to delete the machine package and start with a clean one.
(Right-click / Delete computer / Check "Delete configuration only")
ryoken95
February 28, 2018 - 11:04
Thank you for your help :)
February 28, 2018 - 11:19
To explain the reason for this check:
When modifying a machine's configuration, under the hood, you retrieve a WAPT package from the server named after the machine's UUID, add or remove dependencies, re-sign it with your key, and re-upload it to the server with an incremented version.
If a malicious actor has previously placed a package on the server—necessarily incorrectly signed because they lack an approved key—containing dangerous code, you could unwittingly approve this malicious code by modifying the machine's configuration and re-signing it.
