[RESOLVED] WAPT 1.5 Update (Windows)
beryl
Registration: August 19, 2015 - 1:41 PM
March 14, 2018 - 5:36 PM
Thank you :)
. Could you please provide me with the link to the guide for restoring my WAPT backup?
March 14, 2018 - 5:49 PM
If you had a virtual machine, you can simply restore the snapshot.
Otherwise, for the backup:
https://www.wapt.fr/fr/doc-1.3/Installa ... x.html#id2
Just to clarify, could you tell me if it's a Windows Server x86 or x64?
March 14, 2018 - 5:55 PM
beryl
March 14, 2018 - 6:15 PM
For the time being, and given the urgency, I'm going to attempt a minimal migration to Windows:
So, if I back up the folders: c:\wapt\waptserver\repository\wapt and C:\private,
uninstall WAPT 1.3.13
install WAPT 1.5
, and follow the procedure you indicated , will that be sufficient?
Thank you
. Yes, it is indeed a 64-bit version of Windows 2008R2.
March 14, 2018 - 6:20 PM
To put it simply, do you have an internal Active Directory?
beryl
March 14, 2018 - 8:55 PM
Yes, I have an Active Directory (Windows 2012 R2)
March 15, 2018 - 09:21
So yes, you can install a new WAPT server version 1.5 alongside the existing WAPT 1.3 server.
You can then deploy the 1.5 agent via GPO using waptdeploy.
To re-import all the packages from the old server to the new one, you can add your old server as an external repository in your WAPT 1.5 console and re-import all the packages.
Then, we rely on GPOs and waptdeploy to deploy the new agent version 1.5.
beryl
March 15, 2018 - 12:40
I uninstalled WAPT 1.5, rebooted Windows 2008R2 x64,
and then reinstalled WAPT 1.5. I get exactly the same error. :o :cry:
beryl
March 16, 2018 - 10:23
I just reinstalled Windows Server 2012 R2 x64 (fresh install).
I'm getting the exact same error as you with Windows Server 2008 R2. :(
March 16, 2018 - 11:55
I just tried it again and
it works for me.
What virtualization system do you have?
