Complete Wapt update from 1.3 to 1.5 on Debian
Anthony Jimenez
Registration: March 15, 2018 - 11:53
March 15, 2018 - 11:59
During the installation of the update to the new version of WAPT, I get the following message:
Unable to retrieve https://wapt.tranquil.it/debian/wapt-1. ... 6/Packages The requested URL returned error: 404
See attached image.
Thank you for your help.
AJ
TomTomGo
Registration: May 3, 2017 - 3:36 p.m.
March 15, 2018 - 12:15
I think this is due to your version of Debian 7.0 (Wheezy), as version 1.5 is only supported on 8.0 (Jessie) or 9.0 (Stretch)
https://wapt.tranquil.it/debian/wapt-1.5/dists/
Regards,
agauvrit
Registration: Nov 17, 2016 - 10:25
March 15, 2018 - 12:17
Hello Mathieu ;)
Indeed, as TomTomGo says, the repository address displayed as "wheezy" indicates either your server is running Debian Wheezy, which is incompatible with WAPT 1.5, or there's a leftover file
/etc/apt/sources.list.d/wapt.list
It should contain the following value:
"deb  https://wapt.tranquil.it/debian/wapt-1.5/ stretch main"
Alexander
Anthony Jimenez
March 15, 2018 - 12:32
My server is running the Wheezy version!
Am I forced to change versions, and does that mean a complete reinstallation of Waptserver?
What do you advise?
Thanks,
Anthony
Anthony Jimenez
March 15, 2018 - 2:04 PM
So, I've upgraded to Debian Jessie.
I'm restarting the upgrade process to 1.5, but I'm getting the following messages during the Debian configuration step (see attached image).
Thanks for your help, guys. :)
agauvrit
March 15, 2018 - 2:10 PM
WAPT Server can now only on Debian Linux amd64 Stretch
Anthony Jimenez
March 15, 2018 - 2:13 PM
Hi Alex,
do I have to delete everything and start from scratch?
Or can I simply update Debain Jessie to Stretch?
Thanks
agauvrit
March 15, 2018 - 2:17 PM
Since you seem to be on an x86 version of Debian, it won't work properly.
The simplest solution would be:
  • install a clean Debian Stretch amd64 VM
  • install WAPT 1.5
  • import the packages from your old server to the new one (either via the console or rsync+re-signature in the command line)
  • push the new agent via GPO
Anthony Jimenez
March 15, 2018 - 3:46 PM
Okay, thanks A!
I'll get to it on Monday or Tuesday!
See you later,
Anthony
Anthony Jimenez
March 22, 2018 - 3:22 PM
I just upgraded to Debian 9 Stretch.
However, I'm getting the following error when I configure the repositories: (see attached file)
