I'm having a problem (actually two...) when creating the agent on a fresh WAPT 1.5 installation under Windows.
First, I don't understand the purpose of the "Verify HTTPS server certificate" checkbox in the agent creation interface.
In any case, I had to uncheck it; otherwise, the agent wouldn't be created, displaying the error message shown in the attached image (Attachment 1).
Second, and more annoyingly, if I uncheck this box, the agent creation process does proceed and seems to complete normally (see Attachment 2). However, I can't access the agent from the web interface (Attachment 3).
For your information, I created the agent directly from the server.
Any ideas?
Thanks in advance.
[SOLVED] Problem creating the agent
If your server's certificate (srvwaptav.lyceestjo.fr) is not valid (self-generated and not issued by a recognized certification authority, e.g., Gandi), then it is normal that it does not work.
This procedure is documented: https://www.wapt.fr/fr/doc/Installation ... icate.html
When sending the agent, this certificate is checked and this also prevents it from being sent to the server; fix this issue and it will be functional.
Alexander
The checkbox allows you to verify the HTTPS SSL/TLS certificate of your WAPT server during exchanges with the agent.First, I don't understand the purpose of the "verify HTTPS server certificate" checkbox in the agent creation interface.
In any case, I had to uncheck it; otherwise, the agent wouldn't be created, resulting in the error message shown in the attached image (AP1).
Alexander
- WAPT Expert
Just to be sure, I tried again, and it works for me.
The documentation says to modify the Windows firewall on the WAPT server. But perhaps your antivirus also acts as a firewall and is blocking port 8443?
On the server, the interface responds at: https://127.0.0.1:8443 ??
Yes, that works. I can access the server's homepage on the LAN.
However, I just saw in the documentation that the private key and certificate should be created from another machine.
But I did it directly on the server by installing waptsetup...
Could that be the reason for my problem?
Thanks.
Thanks.
- WAPT Expert
This is indeed not recommended for safety reasons.PPE wrote: ↑March 20, 2018 - 8:19 AM Yes, that answers your question. I can access the server's homepage on the LAN.
However, I just saw in the documentation that the private key and certificate creation should be done from another machine.
Thanks.
But that doesn't explain your problem
Okay... Well, I'm stuck. I tested the link to waptdeploy and it works. (see attached image)
In which folder should waptsetup be saved so I can check if it's there?
Thanks.
Thanks.
- Attachments
- Screenshot 2018-03-20 at 09:54:14.png (19.89 KB) Viewed 11406 times
- WAPT Expert
As Simon indicated:
The presence of this installer is not essential for the proper functioning of the WAPT server; this installer will only be used when installing your console on the administrator's workstation.
Alexander
As Simon indicated:
Pour la suite, télécharger manuellement WAPTSetup depuis : https://wapt.tranquil.it/wapt/releases/latest/waptsetup.exeAlexander
Hello Alexandre,
As I mentioned earlier, I've already downloaded this "generic" waptsetup. My problem concerns the "custom" waptserver-tis.exe file which, despite the agent generation running correctly, isn't available via the server link.
So I'm trying to verify that the waptserver-tis.exe file is saved in the correct location on the server... but I don't know where to look.
I hope that's clear...
