[SOLVED] Problem creating the agent
PPE
Registration: March 19, 2018 - 5:03 PM
March 19, 2018 - 5:15 PM
I'm having a problem (actually two...) when creating the agent on a fresh WAPT 1.5 installation under Windows.
First, I don't understand the purpose of the "Verify HTTPS server certificate" checkbox in the agent creation interface.
In any case, I had to uncheck it; otherwise, the agent wouldn't be created, displaying the error message shown in the attached image (Attachment 1).
Second, and more annoyingly, if I uncheck this box, the agent creation process does proceed and seems to complete normally (see Attachment 2). However, I can't access the agent from the web interface (Attachment 3).
For your information, I created the agent directly from the server.
Any ideas?
Thanks in advance.
agauvrit
Registration: Nov 17, 2016 - 10:25
March 19, 2018 - 5:49 PM
First, I don't understand the purpose of the "verify HTTPS server certificate" checkbox in the agent creation interface.
In any case, I had to uncheck it; otherwise, the agent wouldn't be created, resulting in the error message shown in the attached image (AP1).
The checkbox allows you to verify the HTTPS SSL/TLS certificate of your WAPT server during exchanges with the agent.
If your server's certificate (srvwaptav.lyceestjo.fr) is not valid (self-generated and not issued by a recognized certification authority, e.g., Gandi), then it is normal that it does not work.
This procedure is documented: https://www.wapt.fr/fr/doc/Installation ... icate.html
When sending the agent, this certificate is checked and this also prevents it from being sent to the server; fix this issue and it will be functional.
Alexander
March 19, 2018 - 6:21 PM
Just to be sure, I tried again, and it works for me.
The documentation says to modify the Windows firewall on the WAPT server. But perhaps your antivirus also acts as a firewall and is blocking port 8443?
On the server, the interface responds at: https://127.0.0.1:8443 ??
PPE
March 20, 2018 - 08:19
Yes, that works. I can access the server's homepage on the LAN.
However, I just saw in the documentation that the private key and certificate should be created from another machine.
But I did it directly on the server by installing waptsetup...
Could that be the reason for my problem?
Thanks.
March 20, 2018 - 08:31
PPE wrote: ↑March 20, 2018 - 8:19 AM Yes, that answers your question. I can access the server's homepage on the LAN.
However, I just saw in the documentation that the private key and certificate creation should be done from another machine.
Thanks.
This is indeed not recommended for safety reasons.
But that doesn't explain your problem
PPE
March 20, 2018 - 09:55
Okay... Well, I'm stuck. I tested the link to waptdeploy and it works. (see attached image)
In which folder should waptsetup be saved so I can check if it's there?
Thanks.
Screenshot 2018-03-20 at 09:54:14.png
Screenshot 2018-03-20 at 09:54:14.png (19.89 KB) Viewed 11408 times
PPE
March 20, 2018 - 10:02
I misspoke. I was referring to waptsetup-tis.exe, the waptsetup file that should be located on my server.
Thank you.
agauvrit
March 20, 2018 - 10:05
As Simon indicated:
Pour la suite, télécharger manuellement WAPTSetup depuis : https://wapt.tranquil.it/wapt/releases/latest/waptsetup.exe
The presence of this installer is not essential for the proper functioning of the WAPT server; this installer will only be used when installing your console on the administrator's workstation.
Alexander
PPE
March 20, 2018 - 11:03
Hello Alexandre,
As I mentioned earlier, I've already downloaded this "generic" waptsetup. My problem concerns the "custom" waptserver-tis.exe file which, despite the agent generation running correctly, isn't available via the server link.
So I'm trying to verify that the waptserver-tis.exe file is saved in the correct location on the server... but I don't know where to look.
I hope that's clear...
