WAPT 1.5.1.22 No longer connected to WAPTConsole
joris.remandet
Registration: January 16, 2018 - 6:29 PM
March 28, 2018 - 00:13
I updated to version 1.5.1.22, and I can no longer log in to my WAPT console (the password is correct). The symptom is that it always returns to the login screen... I've tried uninstalling the console and rebooting the server, but nothing works. Any solutions?
March 28, 2018 - 00:48
We had this issue a few days ago, but it should be resolved:
https://github.com/tranquilit/WAPT/comm ... b91c2e4332
Did you install the latest build? (I just tested it again and it works for me):
https://wapt.tranquil.it/wapt/releases/wapt-1.5.1.22/
Could you please provide the logs: waptserver.log
joris.remandet
March 28, 2018 - 01:29
The /var/log/waptserver.log folder is empty; it's not being populated.
Edit: I can confirm that this is indeed the latest build, and I'm still having the same problem. I even tried uninstalling everything and reinstalling, and it's the same.
I'm hesitant to do a clean install...
Imp83
Registration: February 19, 2018 - 12:07
March 28, 2018 - 08:41
I have the same problem. I tried restarting the postconf to reset the admin password, but it didn't work.
March 28, 2018 - 08:46
I thought you were using a Wapt Windows server.
Remember to be as precise as possible when posting on the forum!
We should try:
systemctl stop waptserver
bash /opt/wapt/runwaptserver.sh -ldebug
You need to see if you see anything go by
March 28, 2018 - 08:51
Imp83 wrote: ↑March 28, 2018 - 08:41 I have the same problem. I tried restarting the postconf to reset the admin password, but it didn't work.
Windows Linux?
viewtopic.php?f=13&t=887
Anthony Jimenez
Registration: March 15, 2018 - 11:53
March 28, 2018 - 08:56
Hi
, same problem here on Linux, the console won't open and I get an error message (attached).
March 28, 2018 - 09:00
Anthony JIMENEZ wrote: ↑March 28, 2018 - 08:56 Hi
The problem seems to be an SSL error for you; are others getting the same message?
By the way: Linux? Windows? For the server? ...
Imp83
March 28, 2018 - 09:04
sfonteneau wrote: ↑March 28, 2018 - 08:51
Windows Linux?
Debian Jessie
Anthony Jimenez
March 28, 2018 - 09:05
No, I have the same problem when opening my console, which is already installed at version 1.5.1.21.
It updated correctly to 1.5.1.22, but the password doesn't work... I've tried postconf twice, but still nothing.
It's when I run waptconsole.exe, downloaded from the tranquil.it repository, that I get an SSL error.
