I updated to version 1.5.1.22, and I can no longer log in to my WAPT console (the password is correct). The symptom is that it always returns to the login screen... I've tried uninstalling the console and rebooting the server, but nothing works. Any solutions?
WAPT 1.5.1.22 No longer connected to WAPTConsole
- WAPT Expert
We had this issue a few days ago, but it should be resolved:
https://github.com/tranquilit/WAPT/comm ... b91c2e4332
Did you install the latest build? (I just tested it again and it works for me):
https://wapt.tranquil.it/wapt/releases/wapt-1.5.1.22/
Could you please provide the logs: waptserver.log
joris.remandet
- Registration: January 16, 2018 - 6:29 PM
The /var/log/waptserver.log folder is empty; it's not being populated.
Edit: I can confirm that this is indeed the latest build, and I'm still having the same problem. I even tried uninstalling everything and reinstalling, and it's the same.
I'm hesitant to do a clean install...
- WAPT Expert
I thought you were using a Wapt Windows server.
Remember to be as precise as possible when posting on the forum!
We should try:
You need to see if you see anything go by
We should try:
systemctl stop waptserver
bash /opt/wapt/runwaptserver.sh -ldebug
- WAPT Expert
Anthony Jimenez
- Registration: March 15, 2018 - 11:53
Hi
, same problem here on Linux, the console won't open and I get an error message (attached).
- Attachments
- Capture.PNG (5.1 KB) Viewed 13991 times
- WAPT Expert
The problem seems to be an SSL error for you; are others getting the same message?Anthony JIMENEZ wrote: ↑March 28, 2018 - 08:56 Hi
By the way: Linux? Windows? For the server? ...
Debian Jessie
Anthony Jimenez
No, I have the same problem when opening my console, which is already installed at version 1.5.1.21.
It updated correctly to 1.5.1.22, but the password doesn't work... I've tried postconf twice, but still nothing.
It's when I run waptconsole.exe, downloaded from the tranquil.it repository, that I get an SSL error.
