Following the server update to version 1.5.1.22, I switched to a machine that had remained on version 1.3.13 for a few weeks (automatic agent updates often don't work on my network...). I therefore manually reinstalled the 1.5.1.22 agent on the machine, but it doesn't work (database disk is malformed error). Here is the complete message in the screenshot:
https://preview.ibb.co/nMLwN7/wapt1_5_1_22.png
[Resolved] Problem updating wapt agent 1.5.1.22
I hadn't seen that before.
Apparently the small database of the wapt client is corrupted.
Simple solution: delete the .sqlite file. It is located in
It will be recreated empty. The only problem is that dependent packages will reinstall themselves because the wapt client no longer knows what is installed.
Hubert
<repertoire de wapt>\db\waptdb.sqliteHubert
