Crash when opening the console
patdu59
Registration: Apr 16, 2018 - 2:05 p.m.
April 16, 2018 - 2:09 PM
When I try to open the WAPT console, I consistently get an error message and it is impossible to open.
I've attached a screenshot.
Could you please tell me how to fix this problem?
Thank you in advance for your help
April 16, 2018 - 3:29 PM
Hello Patdu59,
patdu59 wrote: ↑Apr 16, 2018 - 2:09 PM When I try to open the WAPT console, I consistently get an error message and it won't open.
Based on the screenshot you attached to your message, it appears that you are installing the Windows version of the WAPT server, and not the WAPT console.
Could you please indicate the WAPT version and the OS, cf. viewtopic.php?f=9&t=886
patdu59
April 16, 2018 - 5:39 PM
Hello Denis,
Thank you for your reply.
My mistake, it is indeed a problem with the server.
It's the very latest version of WAPT (1.5.23).
My OS is Windows 7 Pro 64-bit.
Regards
April 17, 2018 - 7:45 PM
Hello patdu59,
patdu59 wrote: ↑Apr 16, 2018 - 5:39 PM Thank you for your reply.
It's the very latest version of Wapt (1.5.23).
Regards
Do you have User Account Control (UAC) enabled? Has the nssm.exe file you mentioned been "eaten" by a greedy antivirus program? Do you have something already listening on port 80 or 443?
