Uninstalling OFFICE 2013
fbst
Registration: Oct 24, 2018 - 3:59 p.m.
October 24, 2018 - 4:26 PM
Hello everyone,
I am experiencing problems uninstalling OFFICE 2013 Standard via WAPT.
I've tried different ways to uninstall everything, but I can't manage it.
First, via the uninstallkey:
I retrieved the UID via wapt-get list-registry, which gave me quite a few, but when I try to uninstall it from PyScripter it doesn't work (return:
Ligne de Commande : uninstall "C:\waptdev\Office2013Std_32bits-wapt\WAPT\.."
Uninstalling C:\waptdev\Office2013Std_32bits-wapt ...
None
Uninstallation done)
The uninstallkey looks like this:
uninstallkey = ['{90150000-002A-0000-1000-0000000FF1CE}','{90150000-002A-040C-1000-0000000FF1CE}','Office15.STANDARD','Office2013Std_32bits','{90150000-0012-0000-0000-0000000FF1CE}','{90150000-001F-0401-0000-0000000FF1CE}','{90150000-001F-0407-0000-0000000FF1CE}','{90150000-001F-0409-0000-0000000FF1CE}','{90150000-001F-040C-0000-0000000FF1CE}','{90150000-001F-0413-0000-0000000FF1CE}','{90150000-001F-0C0A-0000-0000000FF1CE}','{90150000-002C-040C-0000-0000000FF1CE}','{90150000-006E-040C-0000-0000000FF1CE}','{90150000-00E1-040C-0000-0000000FF1CE}','{90150000-00E2-040C-0000-0000000FF1CE}']
I also tried using the uninstallstring, and I get the same message as with the uninstallkey:
None
The uninstallstring looks like this:
uninstallstring =['"C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\Office Setup Controller\Setup.exe /uninstall Standard /config silent.xml"']
I tried using an uninstall() function that displays the contents of uninstallstring:
    print("Desinstallation d\'Office")
    run('"C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\Office Setup Controller\Setup.exe /uninstall Standard /config silent.xml"')
back:
Desinstallation d'Office
2018-10-24 16:11:02,690 CRITICAL Fatal error in uninstall function: CalledProcessErrorOutput: Command '"C:\\Program Files (x86)\\Common Files\\Microsoft Shared\\OFFICE15\\Office Setup Controller\\Setup.exe /uninstall Standard /config silent.xml"' returned non-zero exit status 1.
Output:Le chemin d'accÇùs spǸcifiǸ est introuvable.
  File "c:\wapt\waptpackage.py", line 1843, in call_setup_hook
    hookdata = hook_func()
  File "C:\waptdev\Office2013Std_32bits-wapt\setup.py", line 39, in uninstall
  File "c:\wapt\common.py", line 3317, in run
    return ensure_unicode(setuphelpers.run(*arg,pidlist=self.pidlist,**args))
  File "c:\wapt\setuphelpers.py", line 1044, in run
Output:Le chemin d'accŠs sp‚cifi‚ est introuvable.
FATAL ERROR : CalledProcessErrorOutput: Command '"C:\\Program Files (x86)\\Common Files\\Microsoft Shared\\OFFICE15\\Office Setup Controller\\Setup.exe /uninstall Standard /config silent.xml"' returned non-zero exit status 1.
Exit code:  3
The installation goes very well, it is completely transparent, the MSP file is in the right place, same for the silent.xml file.
When I run the following command in a shell, it works perfectly and silently....
I tried different things, I tried passing my paths via a variable in "raw":
r"C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\Office Setup Controller\Setup.exe /uninstall Standard /config silent.xml"
The result is the same, yet I thought I understood that the "r" or the act of surrounding the expression with "expression" escaped the spaces and slashes...
I also tried using the "pathlib" library, but it's not integrated into WAPT, and I couldn't get it to work.
I've included my entire setup.py file below in case it gives you some ideas, but there's nothing particularly original about it compared to the various topics on OFFICE that can be found in the forums :)
Thanks in advance!
fbst
import time
windowspath64 = r"C:\Program Files (x86)\Common Files\microsoft shared\OFFICE15\Office Setup Controller"
windowspath32 = r"C:\Program Files\Common Files\microsoft shared\OFFICE15\Office Setup Controller"
waptpath = r"C:\waptdev\Office2013Std_32bits-wapt\Microsoft Office 2013 32bits"
if iswin64():
	uninstallstring =['"%s\Setup.exe /uninstall Standard /config silent.xml"',windowspath64]
	uninstallstring =['"C:\Program Files (x86)\Common Files\Microsoft Shared\OFFICE15\Office Setup Controller\Setup.exe /unininstall Standard /config silent.xml"']
    def killsoft():
      for soft in ('WINWORD.EXE','POWERPNT.EXE','EXCEL.exe','MSPUB.EXE','MSACCESS.EXE','INFOPATH.EXE','lync.exe','ONENOTE.EXE','OUTLOOK.EXE','ONENOTEM.EXE','MSOSYNC.EXE','GROOVE.EXE'):
        if isrunning(soft):
           print ("closing %s" % soft)
           killalltasks(soft)
    softname = 'Microsoft Office Professionnel Standard 2013'
    check_installed_out = installed_softwares(softname)
    if not check_installed_out:
            print('installing Office 2013')
            killsoft()
            cmd = ('%s\setup.exe /adminfile setup.msp /config silent.xml',waptpath)
            time.sleep(30)
            filecopyto("silent.xml",("C:\Program Files\Common Files\"))
            print('repair Office 2013')
            killsoft()
            cmd = '"C:\Program Files (x86)\Common Files\microsoft shared\OFFICE15\Office Setup Controller\setup.exe" /repair Standard /config silent.xml"'
October 24, 2018 - 4:45 PM
Hello fbst,
fbst wrote: ↑Oct 24, 2018 - 4:26 PM FATAL ERROR: CalledProcessErrorOutput: Command '"C:\\Program Files (x86)\\Common Files\\Microsoft Shared\\OFFICE15\\Office Setup Controller\\Setup.exe /uninstall Standard /config silent.xml"' returned non-zero exit status 1.
Output: The specified access path could not be found.
You need to specify the full path to the silent.xml file since it's not in the same directory as setup.exe. Alternatively, you need to define the working directory.
fbst
October 24, 2018 - 5:41 PM
Thank you for the quick reply, I managed to find a starting point for a solution!
It works well locally on the server directly (installation/uninstallation)
Here is the code:
import time
softname = 'Microsoft Office Standard 2013'
    def killsoft():
        if isrunning(soft):
           print ("Fermeture de %s" % soft)
           killalltasks(soft)
        open(makepath(programfiles32,'silent.xml'), "w" ).write(silentxml)
        print('Installation d\' Office 2013')
        cmd = '"C:\waptdev\Office2013Std_32bits-wapt\Microsoft Office 2013 32bits\setup.exe" /adminfile "setup.msp"'
        remove_file(makepath(programfiles32,'silent.xml'))
        print('Reparation d\'Office 2013')
        cmd = '"C:\waptdev\Office2013Std_32bits-wapt\Microsoft Office 2013 32bits\setup.exe" /repair Standard /config silent.xml"'
    killsoft()
            error('%s : clef de desinstallation non trouvée',softname)
    run('"%s" /uninstall Standard /config "%s"' % (makepath(programfiles32,'Common Files','microsoft shared','OFFICE15','Office Setup Controller','Setup.exe'),makepath(programfiles32,'silent.xml')),timeout=1200)
silentxml = ur"""<Configuration Product="Standard">
<Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" />
   <Setting Id="SETUP_REBOOT" Value="NEVER" />
</Configuration>"""
However, once built and uploaded, when I try to install it on a remote machine, I get an error message:
  File "C:\Program Files (x86)\wapt\waptservice\service.py", line 1374, in run
    self.running_task.run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 515, in run
    self._run()
  File "C:\Program Files (x86)\wapt\waptservice\waptservice_common.py", line 960, in _run
Exception: Erreur lors de l'installation de [u'4C4C4544-0057-5810-8039-B8C04F534632(=2)']: erreurs dans les paquets [[u'4C4C4544-0057-5810-8039-B8C04F534632(=2)', PackageEntry(u'4C4C4544-0057-5810-8039-B8C04F534632',u'2') , u'Traceback (most recent call last):\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 4372, in install\n    force=force\n  File "C:\\Program Files (x86)\\wapt\\common.py", line 3591, in install_wapt\n    raise e\nEWaptUnavailablePackage: Missing dependencies: Office2013Std_32bits\n']]
    self._run()
Any ideas by any chance? :/
Thanks in advance,
Sincerely
fbst
October 24, 2018 - 6:34 PM
Further to my previous message, I would like to clarify that the fact that I specify the full path to setup.exe:
This is because if I put setup.exe by itself, I get a message telling me that setup.exe is not found.
For your information, here is the directory structure of my package:
The setup file is in the root directory, and I've also copied it to the WAPT folder and then to the Microsoft Office 2013 32-bit folder. So I'm having a little trouble understanding where the working directory of the Python script is... could someone please help me? :)
Could the fact that the path is hardcoded in the script be generating the above error?
Furthermore, to try and be as thorough as possible, here is my package displayed in the console:
I get the message when I right-click on a host / Add a dependency / I check the package and then I click on launch installations.
(I'm mentioning this in case I make a mistake) :) )
Finally, here is the package's control file:
Thank you so much... have a good evening
October 25, 2018 - 7:45 PM
Good evening fbst,
fbst wrote: ↑Oct 24, 2018 - 6:34 PM Further to my previous message, I would like to clarify that the fact that I specify the full path to setup.exe:
The setup.py script is executed in a temporary directory with a randomly generated directory name. If the installer needs a full execution path, I should be able to use something like:
import os
dir_path = os.path.dirname(os.path.realpath(__file__))
In your case:
cmd = '"%s\setup.exe" /adminfile "%s\setup.msp"' % (dir_path,dir_path)
fbst
October 30, 2018 - 3:25 PM
Sorry for the slightly long response time...
Thank you for your reply
After testing, it appears that this does not work any better:
I get this message when deploying the package on Windows 7 with Office 2010 installed:
Installation d' Office 2013
  File "C:\Program Files (x86)\wapt\common.py", line 3512, in install_wapt
  File "c:\windows\temp\wapt83htmv\setup.py", line 23, in install
  File "C:\Program Files (x86)\wapt\common.py", line 3317, in run
  File "C:\Program Files (x86)\wapt\setuphelpers.py", line 1044, in run
CalledProcessErrorOutput: Command '"c:\\windows\\temp\\wapt83htmv\\setup.exe" /adminfile "c:\\windows\\temp\\wapt83htmv\\setup.msp" /config "c:\\windows\\temp\\wapt83htmv\\silent.xml"' returned non-zero exit status -2146368439.
Output:
Output:
The MSP file is configured to uninstall older versions:
here is my code
import os
dir_path = os.path.dirname(os.path.realpath('__file__'))
    def killsoft():
        if isrunning(soft):
           killalltasks(soft)
        killsoft()
        cmd = '"%s\setup.exe" /adminfile "%s\setup.msp" /config "%s\silent.xml"' % (dir_path,dir_path,dir_path)
        killsoft()
        print('Deinstallation d\'office')
        cmd = '"%s\setup.exe" /uninstall Standard /config "%s\silent.xml"' % (dir_path,dir_path)
    killsoft()
    run('"%s" /uninstall Standard /config "%s"' % (makepath(programfiles32,r'Common Files',r'microsoft shared','OFFICE15',r'Office Setup Controller','Setup.exe'),makepath(programfiles32,'silent.xml')),timeout=1200)
The files setup.exe / setup.MSP / silent.xml are located in the root of the office package along with setup.py and all office folders.
I confess I'm having a little trouble understanding the problem I'm having :)
thanks in advance,
Sincerely
EDIT: and I confirm that a folder in windows/temp/XXXX is indeed created on the client machine, with all the office files present in the package on the server (setup.msp, setup.py, silent.xml + all the office folders)
