Update WAPT Server version: 1.7.4 pb Waptdeploy
maintenancevla
Registration: March 21, 2018 - 2:30 PM
June 27, 2019 - 2:30 PM
Good morning
I'm sending this email because I'm stuck
For some time now I have been updating the wapt server, then I generate a new agent, and I copy the hash into the gpo script.
And nothing works.
When I launch the waptdeploy installation directly on the machine, I get this message. I've already changed the server name; it's now srv-wapt instead of wapt (already a bad start). I can see that it's the correct path, but I have a double backslash at the end
wapt deploy.JPG (22.8 KB) Viewed 5133 times
here is the GPO in question
wapt deploy1.JPG (146.52 KB) Viewed 5133 times
I've been using Wapt for over 2 years and this is the first time I'm having trouble deploying it (at worst I'll set up a scheduled task)
PS: Otherwise, how do I make sure the WaptTray is always visible during installation, please?
Thanks in advance
- Installed WAPT version: 2.6.0.16795
- Server OS: Debian 11
- Administration/package creation machine OS: Windows Server 2019
maintenancevla
June 27, 2019 - 4:38 PM
Okay, now I'm starting to see the light at the end of the tunnel
BUT I NEED YOU :D
I reinstalled waptserver, purge dns etc
And that's all I have left to do
Thanks in advance
However, during the installation I did regenerate a new certificate and recreate the agent
July 4, 2019 - 12:18
maintenancevla wrote: ↑June 27, 2019 - 4:38 PM Okay, I'm starting to see the light at the end of the tunnel
BUT I NEED YOU. :D
I reinstalled WaptServer, purged DNS, etc.
And now all I have left is this:
Untitled.jpg.
Thanks in advance.
Yet during the installation, I did regenerate a new certificate and recreate the agent.
Could you please tell us the command line you are using in your GPO?
