[SOLVED] WAPT console migration
vandatt
Registration: Nov 30, 2018 - 11:44
October 11, 2019 - 4:40 PM
As part of a domain migration, I need to migrate the administration console to the new domain. I retrieved the private key from the console on the old domain and tried to use it on the new console on the new domain (local WAPT configuration --> path to the personal certificate). However, when I click on "Verify associated key", I get the following message:
Error: No private key in directory C:\private could be decrypted with supplied password, or none matches the certificate
. I am certain of my password.
Do you have a solution?
PS: WAPT version: 1.5.1.26 / Server OS: Linux Debian Stretch / Administration machine OS: Windows 10
Best regards,
Haut
October 12, 2019 - 11:23
Potential problems:
* File extensions?
Private key = .pem
Certificate = .crt
* Both files must be in the same folder, and you must specify the certificate in the console
