[SOLVED] Multiple subnet possible?
PierreM
Registration: May 1, 2019 - 03:39
October 14, 2019 - 07:04
Hello everyone,
we have two different subnets for our computers, one of which is not visible through the WAPT console. Is there a way to use both?
We are on a Windows installation, Community version 1.7.3.5.
Thank you in advance and have a good day!
October 14, 2019 - 09:13
Hello.
As long as all agents can see the WAPT server, it's fine.
If the console or the server can't see the agent, some functions won't be available: Wake-on-LAN, VNC, RDP, and computer management.
Otherwise, it's all good.
PierreM
October 14, 2019 - 09:18
Thank you for your reply, but the clients are not visible on the console. Is there a procedure to follow?
None of the clients on our second subnet are visible...
Thank you in advance!
October 14, 2019 - 09:37
From the computers that are on the second subnet, are you able (without a proxy) to see the wapt server's web page?
PierreM
October 14, 2019 - 9:40 AM
Yes, here is the status on the post:
Thanks again!
October 14, 2019 - 10:39
I'm referring to this link:
https://waptsrv.lfrd.net:8443
PierreM
October 14, 2019 - 11:01
Indeed, they don't have access.
Thanks for the suggestion; could it be a DNS issue on that subnet?
October 14, 2019 - 11:36
Port not open, or DNS or routing issues.
You need to perform the usual diagnostics: ping, nslookup, telnet, etc.
