Package: tis-java8
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
July 24, 2019 - 3:56 PM
Hello security_error,
security_error wrote: ↑Jul 23, 2019 - 1:52 PM A new version is available: https://java.com/fr/download/manual.jsp
Best regards, as they say at work :)
The latest version of Java 8 is no longer free except for certain types of use. According to https://www.oracle.com/technetwork/java...-faqs.html
This license permits personal use, development, testing, prototyping, demonstrating and some other uses at no cost
If the package is updated on the WAPT store, system administrators could accidentally download it and put their organization in breach of Oracle licensing. And Oracle doesn't take that lightly...
There is a `def update_source()` function in the tis-java package. You can use it to update the package directly in your repository.
Denis Cardon
f4242
Registration: Nov 23, 2016 - 8:51 p.m.
October 16, 2019 - 9:09 PM
Personally, I plan to deploy AdoptOpenJDK's OpenJDK builds as a replacement for Oracle Java after verifying that it doesn't break anything. https://adoptopenjdk.net/
