After configuring Kerberos authentication in Firefox:
H:\>klist
LogonId is 0:0x7ddc0
Cached tickets: (2)
#0>
Client: user @ MYDOMAIN.LAN
Server: krbtgt/MYDOMAIN.LAN @ MYDOMAIN.LAN
KerbTicket encryption type: AES-256-CTS-HMAC-SHA1-96
Ticket flags 0x40e10000 -> forwardable renewable initial pre_authent name_canonicalize
Start time: 2/27/2020 14:33:53 (Local)
End time: 2/28/2020 0:33:53 (Local)
Renewal time: 3/5/2020 14:33:53 (Local)
Session key type: AES-256-CTS-HMAC-SHA1-96
Cache indicators: 0x1 -> PRIMARY
KDC called: SRVDC.MYDOMAIN.LAN
#1> Client: user @ MYDOMAIN.LAN
Server: HTTP/srvwapt.MYDOMAIN.LAN @ MYDOMAIN.LAN
Ticket flags 0x40a10000 -> forwardable renewable pre_authent name_canonicalize
Cache indicators: 0
I tried reinstalling the deb file, but it's the same...
However, I have a question:
When configuring the Firefox server, do I absolutely have to include my domain name? What difference does it make if I don't?
Because it's not the same mistake if I don't include my domain name.
If I enter my domain name, I get a 403 error:
- 2020-02-27 14_34_21-403 Forbidden.png (7.55 KB) Viewed 17180 times
If I don't include my domain name, I get a 401 error:
- 2020-02-27 14_36_49-401 Authorization Required.png (9.9 KB) Viewed 17180 times
I have the impression that the problem occurs when I run this command
msktutil --server DOMAIN_CONTROLER --auto-update --keytab /etc/nginx/http-krb5.keytab --host $(hostname) -N
Using a verbose - - I get this:
root@srvwapt:/home/wapt# msktutil --server srvdc --auto-update --keytab /etc/nginx/http-krb5.keytab --host $(home) -N --verbose
-- init_password: Wiping the computer password structure
-- generate_new_password: Generating a new, random password for the computer account
-- generate_new_password: Characters read from /dev/urandom = 91
-- create_fake_krb5_conf: Created a fake krb5.conf file: /tmp/.msktkrb5.conf-qimnoe
-- reload: Reloading Kerberos Context
-- get_short_hostname: Determined short hostname: srvwapt
-- finalize_exec: SAM Account Name is: srvwapt$
-- try_machine_keytab_princ: Trying to authenticate for srvwapt$ from local keytab...
-- try_machine_keytab_princ: Error: krb5_get_init_creds_keytab failed (Generic preauthentication failure)
-- try_machine_keytab_princ: Authentication with keytab failed
-- try_machine_keytab_princ: Trying to authenticate for host/srvwapt.microtec-agora.lan from local keytab...
-- try_machine_keytab_princ: Error: krb5_get_init_creds_keytab failed (Client not found in Kerberos database)
-- try_machine_password: Trying to authenticate for srvwapt$ with password.
It still makes the entries in /etc/nginx/http-krb5.keytab... Since the rest proceeds without error.
