Hello everyone,
how can I register a Linux machine without it asking for a password?
I tried `wapt-get -m`, but it didn't give me any information about it.
The `host_organizational_unit_dn="` field in `wapt-get.ini` isn't being used either.
[SOLVED] Registering a Linux machine
- WAPT Expert
For registration
host_organizational_unit_dn will be fixed in the next version
wapt-get register --wapt-server-user=admin --wapt-server-passwd=password
Would this work on Windows?sfonteneau wrote: ↑Apr 15, 2020 - 5:50 PM For registrationhost_organizational_unit_dn will be fixed in the next versionCode: Select all
wapt-get register --wapt-server-user=admin --wapt-server-passwd=password![]()
I can't find an option so that during agent installation it doesn't perform the "register" operation and then pass it as a parameter as you indicated.
- WAPT Expert
Yes, absolutely, it works under Windows too.
Kerberos authentication isn't working for you?
We're working on it (see another thread) but since we don't have control over our DC while waiting for the modifications, we wanted to test it this way.sfonteneau wrote: ↑Apr 16, 2020 - 5:11 PM Yes, absolutely, it works under Windows too.
Kerberos authentication doesn't work for you?
- WAPT Expert
For your information, Kerberos authentication will also be possible for Linux and Mac workstations
