We have the enterprise version.
1) Knowing that we only want to install critical and security updates on our client PCs, and that we have configured the filters "Critical only", "All products", and "Security Updates" below in WAPT, are these the only filters necessary and sufficient for what we want to do?
I'm asking because the labels on Wapt are different from those on WSUS. See attached screenshot.
2) The "Pilots" and "Pilot games" classifications do not exist on Wapt. Why?
3) To generate an agent in Wapt, what exactly does the "Allow all updates by default" checkbox do?
Thank you all,
Mr.
Update with Wapt Enterprise
- WAPT Expert
Good morning
Generally, updates are refused by default, then a WUA rule package is created to allow cabs.
You can also allow default severities by adding allowed_severities=critical to the waptwua section of wapt-get.ini:
https://www.wapt.fr/fr/doc/wapt-usage/w ... wapt-agent
Unfortunately, Microsoft's wsusscn2.cab file does not include these categories
This indicates wapt's default behavior towards cabs. It either accepts them by default, or rejects them by default (box unchecked).
- WAPT Expert
Yes, indeed
example package:
example package:
inifile_writestring(makepath(install_location('WAPT_is1'),"wapt-get.ini"),'waptwua','allowed_severities','critical')
Thank you.
Could you answer the first question:
1) We want to install only critical and security updates on our client PCs. Below, in WAPT, we have configured the filters "Critical only," "All products," and "Security Updates." Are these the only filters necessary and sufficient for our purpose?
I ask because the labels in WAPT are different from those in WSUS. See the attached screenshot.
- WAPT Expert
Actually, with "allowed_severities" you allow KBs with the severity level specified in the parameter.
In WaptConsole, this is the criticality column.
There's also the allowed_classifications parameter, which corresponds to the "classification" column, but this parameter is neither documented nor tested
- Attachments
- Annotation 2020-10-30 094019.png (79.17 KB) Viewed 6887 times
So with the configuration currently available on Wapt, I don't have all the critical and security updates?
See the attached file, it's a screenshot of the configuration in question.
Thank you very much and have a good day
Mr.
Mr.
