is it possible to make a package run every time WAPT starts?
I have a package that needs to run once a day (like a scheduled task), but without having to increment the package version every day!
Is there a way to do this?
Thanks in advance.
Execute a package at each machine restart
- WAPT Expert
See the forum rules above.
You could create a scheduled task that performs a force install at each startup. That said, we would need a little more information to give a more informed opinion.
Regards,
Regards,
Hello Denis,
thank you for your reply.
Here's some more information:
Wapt agent version: 1.8.2,
OS: Windows 10.
To elaborate on my request, I have a Python script that retrieves the timezone from the internet based on the user's geographical location (using the IP address). From there, the script applies the correct timezone to the PC by modifying the settings in Windows.
The idea of forcing the script to execute every time Wapt is launched would allow (for people who travel to different timezones) for automatic timezone adjustment.
My goal was to use only Python and not batch scripts or PowerShell.
Thank you in advance.
OS: Windows 10.
Hi florentR2,
thanks for the feedback.
I added the "audit_schedule" attribute to the control file with a value of "1m" but nothing happens.
Do I need to add an "audit" function to setup.py or make another modification?
Thanks in advance.
Thanks in advance.
Yes, you need an audit() function
def audit():
# put here code to check periodically that state is matching expectations
# return "OK", "WARNING" or "ERROR" to report status in console.
# all print statement are reported too
return "OK"
