Problem with build package windows10-upgrade
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
fck_mly
Registration: Sep 1, 2020 - 4:28 p.m.
July 19, 2021 - 10:17
We are encountering an issue when building the latest package, tis-windows10-upgrade version 10.0.19043-76 x64 fr.
The update-package runs correctly either directly from the ISO or with the Media Tool.
However, when launching the build, an error message appears:
ERROR building c:\waptdev\tis-windows10-upgrade_10.0.19043-76_x64_windows_6.1_PROD_fr_dc010bab7796dfce298fe1bcea9ca0e1-wapt: [Errno 2] No such file or directory: 'c:\\waptdev\\tis-windows10-upgrade_10.0.19043-76_x64_windows_6.1_PROD_fr_dc010bab7796dfce298fe1bcea9ca0e1-wapt\\iso\\sources\\replacementmanifests\\microsoft-windows-appx-deployment-server\\microsoft.windows.secondarytileexperience_10.0.0.0_neutral__cw5n1h2txyewy.xml'
The file exists, but the path seems extremely long (268 characters), which makes me think it can't open the file.
What could be the solution so I can build this package?
Would deleting the old windows10-upgrade packages shorten the package directory name?
Thank you in advance for any help you can provide.
fck_mly
July 19, 2021 - 5:52 PM
Okay, a small update regarding this Windows 10 upgrade package, version 10.0.19043-76.
The problem was that, as in previous versions, we were using the "download and edit" option. However, now it downloads the package while keeping the "tis" prefix instead of replacing it with our defined prefix. So, we have to "import" the package, which works, and then edit it from the private repository...
On the other hand, I'm encountering a problem when uploading the package to the server.
I'm getting an error at the end of the package upload:
"Uploading c:\waptdev\pref-windows10-upgrade_10.0.19043-80_x64_windows_0f4137ed1502b5045d6083aa258b5c42_6.1_PROD_fr.wapt: 4325165264 / 4325165264
Done Uploading c:\waptdev\pref-windows10-upgrade_10.0.19043-80_x64_windows_0f4137ed1502b5045d6083aa258b5c42_6.1_PROD_fr.wapt
FATAL ERROR: None: None
Exit code: 3"
Do you have any ideas, please?
July 20, 2021 - 12:01
Hello fck_mly,
could you please check the disk space you have on the /var/lib/nginx directory? The nginx server buffers uploads, and this causes problems if there isn't enough space.
fck_mly
July 20, 2021 - 12:11
Here is the result of the command:
Filesystem      Size  Used Avail Use% Mounted on
/dev/sda3       195G   29G  156G  16% /
I will still remove the old updated packages that are no longer needed.
Following a discussion with Gaëtan on Discord, I uploaded from WinSCP and it went through.
But I'm still having trouble assigning the package to my machines... I apply the package, save it, and it's no longer there when I update the necessary packages... yet, everything is OK in terms of target architecture and minimum WAPT version!
fck_mly
July 20, 2021 - 12:38
Here's a screenshot to illustrate my point…
2021-07-20 12_32_44-Console WAPT.png (101.45 KB) Viewed 70181 times
fck_mly
July 21, 2021 - 2:44 PM
Any ideas? :?
fck_mly
July 22, 2021 - 12:05
I'm trying to make progress little by little regarding my incident.
I have tried again several times, synchronizing, rebooting the repositories but the problem is still present.
I then tried installing it via the self-service interface on the machine, and bingo! It worked without any problems. So, I'm no expert, but I think the package is good.
Here is the content of the control file, as requested by Gaëtan:
package           : alti-windows10-upgrade
version           : 10.0.19043-77
architecture      : x64
section           : base
priority          : optional
name              : Windows 10 Upgrade
categories        : System and network
maintainer        : WAPT Team,Tranquil IT,Jimmy PELÉ
description       : Upgrade to the latest version of Windows 10 from Windows 7, 8 and 10 - You must execute the "update-package" and "build-package" for every single necessary language before deploying the package
depends           :
conflicts         : alti-windows10-upgrade-data,alti-windows10-upgrade,alti-windows10-2004-upgrade,alti-windows10-20h2-upgrade
maturity          : PROD
locale            : fr
target_os         : windows
min_wapt_version  : 1.8.2
sources           : https://www.microsoft.com/software-download/windows10
installed_size    : 25000000000
impacted_process  : SetupHost
description_fr    : Mise à niveau vers la dernière version de Windows 10 à partir de Windows 7, 8 et 10 - Vous devez exécuter le "update-package" et le "build-package" pour chaque langue nécessaire avant de déployer le paquet
description_pl    :
description_de    :
description_es    :
description_pt    :
description_it    :
description_nl    :
description_ru    :
audit_schedule    :
editor            : Microsoft
keywords          :
licence           : Proprietary
homepage          : https://www.microsoft.com/software-download/windows10
package_uuid      : d1d2de4c-964c-4ebb-a4e0-fd077bcfed8e
valid_from        :
valid_until       :
forced_install_on :
changelog         : https://docs.microsoft.com/windows/release-health/
min_os_version    : 6.1
max_os_version    :
icon_sha256sum    : 0f0215b9e420749ac9eb93b5bf0ef17810011c14427248e1b0d72e6699279534
signer            : Altiservice
signer_fingerprint: 0da866ec9c1d100158f92dbed1c58c52477e96fdc4534fba456ad0f7f581dae2
signature         : vVM1GW1dnFnG/wuwQiyzXlKuzFHit2Z2iN67e+j17t/R7uMUsP21ZRv+On7+rF5xRe1V38silECdl5sDd99l68tKyv2CpQTo2PWKkYE3UB+FQ6XkifsRaG+5NU93P/SsVF0BSZzu82h4prjN1onkzg4jgrWW4h6Rj/kPv0ALnMHEMssW4tP/xDhQe7Qni/gIfDRPSEsCQ3BDawJ/yxftlNqAnkkbuTPrwTC7fPvhVgMKOgjJq3qRCLrjRplIbd8QJwLpRQtwpDs66M4YOAaiPlj9SzrQ2z/aa486dsMLaLfRwgz8DyshkaDsrHBmh7iTQGlodjUcDPu3ogGZewX0NA==
signature_date    : 2021-07-20T10:24:30.522030
signed_attributes : package,version,architecture,section,priority,name,categories,maintainer,description,depends,conflicts,maturity,locale,target_os,min_wapt_version,sources,installed_size,impacted_process,description_fr,description_pl,description_de,description_es,description_pt,description_it,description_nl,description_ru,audit_schedule,editor,keywords,licence,homepage,package_uuid,valid_from,valid_until,forced_install_on,changelog,min_os_version,max_os_version,icon_sha256sum,signer,signer_fingerprint,signature_date,signed_attributes
I could go to each machine and launch the installation via self-service, but that defeats the purpose of the tool!
Gaetan
Registration: August 8, 2019 - 10:16
July 22, 2021 - 12:28
Does this only work on machines pointing to a secondary repository?
fck_mly
July 22, 2021 - 12:35
I have the same problem whether the repository is the main one or the secondary repositories.
All three secondary repositories we have have an OK status; the package is present on all three repositories, and the package owner is the "wapt" account...
August 9, 2021 - 3:52 PM
package: alti-windows10-upgrade
conflicts: alti-windows10-upgrade-data,alti-windows10-upgrade, alti-windows10-2004-upgrade, alti-windows10-20h2-upgrade
Problem in the control file
