We're having trouble launching the self-service application since updating to version 2.1.0.10550.
Regular users can no longer launch the self-service application. However,
there are no issues when using the machine administrator.
Could I have missed this part in the changelog?
We're running WAPT 2.1 Enterprise on Ubuntu.
Thank you.
Alban
[SOLVED] Self-service launch (wapt2.1)
- WAPT Expert
Hi Alban,
could you post your wapt-get.ini file? There's a silent crash if the configuration is incorrect, with the parameters `use_kerberos=True` and `service_auth_type = waptserver-ldap`, but the background configuration isn't correct.
Do you have the LDAP and Kerberos configuration set up on the server?
Regards,
Regards,
AlbanUCA63
- Registration: March 18, 2019 - 10:14
Good evening Denis,
Thank you for the information regarding the wapt-get.ini file.
The use_kerberos parameter was set to 1 (which was functional before version 2.1) and not to "True".
I changed it to True on a test machine and it seems OK.
I will confirm tomorrow.
Alban
Alban
AlbanUCA63
Hello everyone, I can confirm that it now works after changing `use_kerberos` from `True` to ` True` . Thank you. Alban
- WAPT Expert
Good evening Alban,
thank you for the feedback!
