I'm sharing my Office Pro 2016 package.
Prerequisites:
Run the command "setup.exe /admin" to generate an MSP file to save in the updates folder of the setup folder containing all the installation files. The setup folder must be copied into the package.
uninstallkey = ['Office16.PROPLUS']
print('installing wapt-office2016pro')
install_exe_if_needed("%s\setup\setup.exe" % basedir,silentflags='',key='Office16.PROPLUS',min_version='16.0.4266.1001',timeout=1200)
uninstallkey.remove('Office16.PROPLUS')
print('uninstalling wapt-office2016pro')
import tempfile
pathuninstallfile = makepath(tempfile.gettempdir(),'SilentUninstall.xml')
data = r"""<Configuration Product="ProPlus"><Display Level="none" CompletionNotice="no" SuppressModal="yes" AcceptEula="yes" /></Configuration>"""
fichier = open(pathuninstallfile, "w")
fichier.write(data)
fichier.close()
run(r'"%s\Common Files\Microsoft Shared\OFFICE16\Office Setup Controller\setup.exe" /uninstall ProPlus /config %s' % (programfiles32,pathuninstallfile))
remove_file(pathuninstallfile)
