WAPT update error from 1.7.4 to 1.8.2.7393
Supportinfo
Registration: January 27, 2022 - 1:00 PM
January 27, 2022 - 1:36 PM
After downloading what I believe are the correct files from the FTP server (there are quite a few), I'm using the Enterprise version on a Windows Server 2016 server.
1/ I first installed waptsetup.exe: the console launches after an error message, but remains at version 1.7.4.
2/ I then installed waptserversetup.exe, using the same certificate and generating a new agent.
The console doesn't open, and I get the following message: HTTP/1.1 401 UNAUTHORIZED, but the prompt specifies that I am indeed on version 1.8.2.7393.
If anyone has any ideas... Thanks in advance.
February 1, 2022 - 4:33 PM
Supportinfo wrote: ↑Jan 27, 2022 - 1:36 PM Hello,
After downloading, I think, the correct files from the FTP (there are quite a few). This is the Enterprise version, on a WS 2016
There's no FTP for downloading... I think you're talking about https://wapt.tranquil.it/wapt/releases/ ... -75a5de09/ There are a lot of files, which is normal, as there are several versions and several supported operating systems, but normally you would download them from the documentation...
Supportinfo wrote: ↑Jan 27, 2022 - 1:36 PM 1/ I first installed waptsetup.exe: the console launches after an error message, but remains at version 1.7.4
2/ So I installed waptserversetup.exe, using the same certificate, and regenerating a new agent.
You should not install waptsetup.exe on the WAPT server under Windows, see the documentation, so it's normal that it didn't work.
Supportinfo wrote: ↑Jan 27, 2022 - 1:36 PM The console won't open and I get the following message: HTTP/1.1 401 UNAUTHORIZED, but the prompt specifies that I am indeed on version 1.8.2.7393.
There's a bit of a lack of information... Is the server running correctly? Is the HTTP test page displaying correctly? Are the login/password correct? Is there a special character in the password (there were some encoding bugs back then)? Do you have any specific information in the server logs?
Supportinfo
February 7, 2022 - 10:48
I'm writing on this forum because the documentation is very sparse. And yes, the updates are downloaded via this FTP server; sorry, that's all I have.
Thank you for your help (or rather, for your comments... I understand that we haven't opted for a "telephone support" solution).
Here's our solution: continue using version 1.7.4 until the end of the subscription, then choose a more user-friendly and simpler deployment solution, which we've already found.
Sincerely.
February 7, 2022 - 8:32 PM
during your installation (which you can restart), could you reset the administrator account password?
Could you please confirm that you are running the installation with the LOCAL administrator account on the server? (not the domain admin account)
