TeamViewer x64
flo777
Registration: February 23, 2022 - 9:35 PM
February 23, 2022 - 9:41 PM
The TeamViewer package 15.26.4-19 (unmodified, imported from the Tranquillit repository) for Windows x64 is not installing on our machines (Windows 7).
The error is as follows:
Removing: TeamViewer (15.15.5)
Installing: TeamViewer_Setup_x64.exe
File "C:\Program Files (x86)\wapt\common.py", line 3877, in install_wapt
File "c:\windows\temp\waptf32sqb\setup.py", line 49, in install
NameError: global name 'get_service_start_mode' is not defined
Indeed, when I look at line 49, this function is called but not defined (not found in setuphelpers.py). https://github.com/tranquilit/WAPT/blob ... helpers.py
Any ideas?
Thanks in advance!
Florian
WAPT version 1.8.2 community. Linux server (Debian)
WAPT Console client under Windows 7
February 28, 2022 - 4:43 PM
Hello Flo777,
the package uses a function introduced in WAPT version 2. We will correct the package. That said, Tranquil IT will end support for WAPT 1.8.2 by the beginning of summer, and therefore package compatibility with version 1.8.2 will also end.
To continue using the store, you will need to migrate to WAPT Discovery (which will be released in mid-March) or to WAPT Enterprise.
Denis Cardon
