Agent OK issue, but disconnected on the console
Jitero
Registration: Apr 14, 2022 - 3:07 p.m.
April 14, 2022 - 3:11 PM
I just upgraded from version 1.8 to 2.2 and now one of my agent machines is no longer reachable, whereas in version 1.8 everything worked correctly.
I would also like to add that on the client machine I have a notification that says "WAPTService stopped"
Installed WAPT version = 2.2.1
Server OS = Windows Server 2019
Administration/package creation machine OS = Windows 10
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 14, 2022 - 3:29 PM
Hello Jitero,
I see this is your first post, so welcome!
If the service is stopped, then the machine will appear disconnected in the console.
We need to understand why the service isn't starting.
What does the log say on the machine in question?
Typically: "C:\Program Files (x86)\wapt\log\waptservice.log"
Consoles: Windows 10 & 11
Infrastructure: Windows
Jitero
April 14, 2022 - 3:45 PM
t.heroult wrote: ↑Apr 14, 2022 - 3:29 PM Hello Jitero,
I see this is your first message, so welcome!
Hello to you too! And thank you for your welcome message!
In the location you mentioned, I have a file named "wapt-get 20220414 145155".
And here is the last line that I see; I imagine this is the one we are interested in.
t.heroult
April 14, 2022 - 4:17 PM
Okay, we'll have to wait for support to intervene because this isn't a message I can interpret :)
Jitero
April 19, 2022 - 8:45 AM
up
April 20, 2022 - 2:00 PM
Good morning
In a command prompt as administrator, can you run this:
runwaptservice -ldebug
Jitero
April 21, 2022 - 09:08
sfonteneau wrote: ↑Apr 20, 2022 - 2:00 PM Good morning
Thank you for your reply, the problem is solved, it was a problem with the antivirus.
Good day !
