Description:
automatic package for Scratch
Package: tis-scratch
* French community support is provided on this forum
* Specify the installed WAPT version (1.8.2 / 2.0 / 2.1 / 2.2 / etc.) AS WELL AS the Enterprise / Discovery edition.
* Specify the server OS (Linux / Windows) and version (Debian Stretch/Buster - CentOS 7 - Windows Server 2012/2016/2019).
* Specify the OS of the administration/package creation machine (Windows 7 / 10)
. * As with any community forum, support is provided voluntarily by members. If you require sales support, you can contact the Tranquil IT sales department at 02.40.97.57.55
Steven Samson - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires
Hello, when trying to update the Scratch package, which was working fine, I get this error message: `
installing scratch2offlineeditor
TimeoutExpired: Command '"Scratch-456.0.4.exe" -silent -eulaAccepted -programMenu' timed out after 300 seconds with output ''`.
What should I do?
Rémi Larché
What should I do?
Rémi Larché
- WAPT Expert
I've already encountered this issue with Scratch.
First things first:
Is Adobe AIR properly installed on the machine?
Do you have an internal proxy server? If so, is your proxy server authenticating?
To confirm the problem I suspect:
Can you unplug the network cable from the machine experiencing the issue? Then shut down that machine.
The goal is for it to be disconnected from the network when WaptExit is launched.
If the installation worked after restarting (without a network connection), it means the installer is trying to communicate with the internet but can't (authentication popup to access the internet?).
I haven't been able to prevent the Scratch installer (or at least Adobe AIR) from connecting to the internet.
First things first:
RaphaëlLarronde
- Registration: Nov 10, 2017 - 11:40
Hello.
I can confirm that the problem is with Adobe Air.
A Scratch package without Adobe dependencies works fine for me, but your package never does.
I do have a proxy, which should be transparent, but...
Best regards
Best regards
- WAPT Expert
I just ran another test at home; I need more information.
Windows XP, 7, 8, 10?
x86? x64?
x86? x64?
RaphaëlLarronde
Good evening.
I'll launch your package on Monday to send you the screenshots.
The server is hosted on Windows 7, and the clients are running Windows 7 32-bit or 64-bit.
Thank you so much for your fantastic tool.
- WAPT Expert
I've thought about it but haven't found a clean solution :-/
Also, I can't always reproduce the problem.
The problem is definitely related to the Scratch installer, and more specifically to Adobe AIR...
For now, the simplest thing might be to adjust the proxy settings to allow the blocking or authentication of the frame that's causing the issue?
In my opinion, Adobe AIR tries to download something like (crl,cab) from Adobe's website to check if the Scratch application has been properly authorized. That's why I can't always reproduce the problem.
Please note that these are just assumptions!
